who has broke a D70?
#31
So what's the consensus here. I just shelled my second d70, and was thinking about putting a locker in it. After reading this thread I'm thinking a boneyard d80 makes a lot more sense. I'm tired of blowing up rears..
If I go d80, what year, model, etc would have the highest spline count?
#32
Pretty sure all the Dodge's came with 35 spline shafts. The Ford F-Superduty's came with 37 spline shafts, but those were dually rear ends that were a 10 lug pattern. Not sure if you could just swap hubs on it to get the normal 8.
#33
I just bought a d80 for $1250, it is from a 02 with disc brakes, should have it by end of week. Not quite sure what it will take to make it work. Drive shaft i think will need to be about 2 inches shorter,(have a thread in 2nd gen drivetrain asking about this), not sure how brake lines & e brake will play out. Go to car-parts.com & do a search for what you are looking for. I priced putting a LSD in my D70 with new r&p bearings & so on & it was $855, & that does not include the new lsd that I allready have. When I get it done I will do a write up on it. If anyone has any insight on this project please chime in. Thanks
#35
not an axle goo-roo
well I new a guy that broke the crud out of his D70 in his 1st gen. So he put a full floater corp.14 out of a chev. I know there a tough unit. I had one in an 87 chev with a 600 hp 454 and running 42's and that 14 bolt never had an problem, plus there cheaper to fix. Now com. to a D80, I am not sure how they compare to one another. just know that guy got his for $200 out of a junk yard when that D70 broke on him.
Bob
Bob
#36
D70 and the 14 bold would be comparable. Same size shafts (different spline count though), same size ring gear, both full float. 14 bolts are a lot easier to setup, almost as nice as a Ford 9".
#37
I used to have a peterson's 4wheel magazine that had all the pros and cons and specs. of all the popular axles out there, but I can't remember where it's at. It was some good reading.
#38
I found two teeth chipped on my D70 Ring Gear and there were gouges in the inside of the cover as well as a large amount of shavings in the oil and on the magnet. The chips are probably 1/4-1/3 of two teeth and have one good tooth in between them. Any immediate concerns or should it be ok for a while?
fordsux8269
23
01-30-2006 07:18 PM
ddestruel
07-02-2005 11:13 AM
