Who has the best I/C boots and clamps?
Old 10-08-2008 | 10:09 PM
bridleman's Avatar
If you were in need of boots and clamps whose would you buy and why? Also do you want to have regular clamps or spring loaded?
Old 10-08-2008 | 10:12 PM
J Lent's Avatar
Spring loaded. I had BD boots, blew a 4" hole through one & bought a set of PDR boots. The PDR are way heavier duty, I'd get them. After the BD blew out, I put a stocker on & pulled again, didn't blow out. I think the spring loaded clamps & stock boots would hold up fine.
Old 10-08-2008 | 11:04 PM
EBunger's Avatar
Peak diesel has some that look to be good to go. I 2nd the spring clamps. Dont skimp on boots either. BDs are only rated for 70lbs the Peaks are like 150lbs.
Old 10-09-2008 | 02:07 AM
99 24v's Avatar
go with the peak boots. they are the best imo. very heavy duty and a pia to install but they are well worth it.
Old 10-09-2008 | 02:31 AM
NMCTD's Avatar
Rip has some nice boots also. Its what I have, just haven't had time to install yet.
5 ply silicone Aramid design. Rated for 500 degrees at continuous use. Tested at 300psi with zero failures. Lifetime warranty on hoses & clamps
http://www.sourceautomotive.biz/inde...emart&Itemid=1
Old 10-09-2008 | 05:53 PM
Bjans's Avatar
mr bobs are the best ive found! spring clamps
Strong05
07-01-2009 02:03 AM
xOmertAx
02-04-2009 03:41 AM
HOHN
45
12-19-2007 10:13 PM
Hoss
32
11-17-2005 11:50 AM
Cumminsdieselboy
07-08-2003 01:58 PM
