white clearance lights question....i need this resolved
Is it illegal to have white clearance lights on the top of my cab?? A few people have told me that they must be amber if they're facing forward but I have seen some white ones before. I have clear clearance lights (clear lenses) but they came with the amber LEDs so I ordered white LEDs to replace them. But if it is illegal for some reason, I won't bother switching the LEDs out, so someone let me know! thanks
Dane
Dane
Yes depending on what state you live in. It is one of those things that you can get away with if for 4 years and then one day it will bite you in the butt.
Ask yourself how bad is the economy in your state. If it is bad and the Bears are hungry for anything to generate and income.
There supposed to be amber when lit. The clear lenses are ok. But at night, they should be amber. Lighting is a highway safety thing. White lights are for roadway illumination, or vehicle identification i.e. license plate (but they can not face forward). All others must be amber (front) or red (rear). If you see white and/or lights, the vehicle is moving toward you. Red, same direction as you. Always better to follow the rules, as Rott-n-dawg states they are definitely looking now.
FWIW The reason the Hat has not been pulled is he has the AHP, and city cops for eighty miles scared of him. When he left SC, you could hear the sigh for three states in all directions...
Administrator/Jarhead
thanks guys, I guess I'll just follow the rules for now.... I just really like the look of the white ones better than the amber ones for some reason. maybe I'll have the lenses tinted so it gives the 'smoked' look and they arent so bright. thanks again.
i live in PA by the way
I just changed out the bulb in one of my clearance lights... can you tell me the best way to prevent leaks? For some reason, I am paranoid it will start leaking now... The guy at the shop said to put a small amount of vasaline around the seal. ?? Any advice anyone??
Just a thought.
Vaseline will soften the rubber of the seals, and help them stay pliable and soft. If the seals look cracked and faded, or seem like they are hardening, you might want to consider replacing them. You can run a garden hose over them and then see if they are leaking under controlled conditions. Might get a couple of drops inside, but not ruin anything. If you did find a leak you would be able to be proactive, not reactive. Always a better situation to be in.
qzilla
29
11-12-2008 04:13 PM
pet05
61
09-30-2007 10:29 PM
qzilla
41
03-30-2007 08:29 AM
cummins dsl
22
06-27-2005 11:53 AM
