Where would I get an 18.5 or 21cm housing?
Yes, I know they are not popular, but I'm considering going to a MUCH larger housing.
I ruled out a 16 because it flows less than a 14wg and spools worse.
Are the 18.5 and 21 housings designed for the H1C, or for the HX35?
Thanks.
Thanks.
Yeah, I took a 21 to the scrap yard that I would have been happy to give you. I would suggest not going bigger than the 18.5 cm. By the time a 21 spools up the EGT is so high that the turbo can't catch up.
Re: Where would I get an 18.5 or 21cm housing?
PeytonMaterne
12-07-2005 11:15 PM
