where to tap in for fuel pressure???
I bought the Westach - Fuel Pressure Gauge Kit - 0-16 psi from Genos garage. Is the only place to hook up to is the schrader valve or get the banjo bolts with the 1 of them being tapped?
I have it hooked up to the schrader valve now and it vibrates loose and leaks fuel all over. What else can a guy do???
thanks
thanks
See if this will help.
http://www.villageforge.com/fuelgauge.pdf
I just installed mine last weekend....Used a tapped banjo bolt at the bottom of the filter housing... works like a champ...no leaks, no fuss...you'll need to get TWO new gaskets...
Dave
Dave
Administrator / Scooter Bum
Originally posted by silverram323
Well i ordered the banjo bolts, Ill try these. If I remember right arn't these bolts also bigger in size then the stockers?
Just be careful don’t over torque them. I’ve heard of a couple of guys twisting off the heads of the bolts. The book calls for 18ftlb. I would just get them good and snug.
Just my $0.02 worth.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
bgilbert
03-02-2006 04:01 PM
