Where to tap in for Egt and Boost Gauges?
Can anyone send pictures of exact locations to tap the exhaust man and intake area for my new autometer gauges, 99 Dodge Diesel. Thanks for your help. Also, I have 4" SS exhuast from the turbo back, AFE Stage 2 Progaurd 7, and the Edge Comp Box, gauges are going to be install when I get a few good opinions on locations to tap....what else would you guys think I might need to make my 5pd run even better (it already runs good in my opinion) Thanks Again!
This should help with install questions.
http://i.b5z.net/i/u/265866/i/Dodge_gauge.pdf
They are using a 1/4" thermocouple for the pyro. Some are 1/8" and some are 1/4". If you have one that is a 1/4" then you can use these instructions. If you have a 1/8" thermocouple lead, then you will need a drill bit that is 1 size smaller. Mine is 1/4", so I dont know what drill bit you would need to use for the 1/8", but I'm sure someone will chime in and let ya know. Hope this helps.
For boost there is a 3/4" plug in the driver side of the block just below the head and right above the fuel filter. Just insert the end of an extension with a ratchet and remove that, then all you need is a reducer that you can get from home depot or where ever and install it there. That's where I put mine anyways and it works great!!
~Nick
~Nick
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
fade94
09-16-2008 11:50 AM
bgilbert
03-02-2006 04:01 PM
