where should i get my next set of injectors
Old 07-27-2006, 09:36 PM
The Guru
Mike Holmen's Avatar
24vford, if your serious about building a set of twins for your truck, buy bigger sticks. You can alway turn off your box with bigger sticks until you have your twins. With twins your should be able to have decent egt's and be able run the big HP numbers without to many side effects.
Old 07-30-2006, 06:41 PM
24Vford's Avatar
well with my current setup i have 400hp and unloaded i cant get it above 1250
but i figured with a new intercooler water meth injection and hopefully ats twins i hope i can run my edge drag comp with the redlinebox with no problem
Old 07-30-2006, 11:19 PM
BIGHEAD's Avatar
When you said water meth injection, you just started detonating your engine in your head. I don't see where you will have an every day driver/ towing vehicle with big sticks & twins. I have some RV 275's DonM honed for me & they work great with the Edge comp & non wastegated HX35, & Suncoast tranny & TC. I can tow a Cat D4 Dozer down the interstate at 85mph on stage 5 & barely get to 1300egt's. Now I shouldn't be driving that fast anyway, so when I back off, I get great fuel mileage & no problems. Either you build a performance truck or an everyday driver. I just don't see an everyday driver with your list of ideas. Just my 2 cents worth. DonM's injectors are the only way to go for sure whatever size you choose.
Old 07-31-2006, 01:39 PM
casper_cobra's Avatar
www.haisleymachine.com
www.neweradiesel.com
both make great custom EDM injectors
irocpractice
04-07-2012 07:01 PM
jgiachino
16
05-25-2008 11:54 AM
Joe T
07-10-2007 02:38 PM
Common
05-06-2007 08:47 AM
tywebb3
06-23-2006 11:30 PM
Quick Reply: where should i get my next set of injectors
