Where are the (no cost mods)...?
Spend a little on gauges before adjusting the fuel, so you don't hurt the motor. The AFC housing is right behind and in line with the top of the injector pump, where the injector lines come out. The spring is inside, access for adjustment (starwheel) through the allen head plug towards the rear. The fuel plate is underneath that, and you have to remove the AFC housing to access it. Do a search for lots of info, and some pics.
www.dodgedieseldatabase.com go to performance then installations then turning up a p7100
RAM123
08-27-2012 11:26 AM
tristan21
06-19-2007 04:57 AM
