where to mount airdog
Old 10-01-2008 | 10:41 PM
vchateau's Avatar
Finally got my AD100 setup...but trying to figure out where to mount it...I've got a 2001 4x4 sb extended cab...I spent an hour underneath the truck tonite and I'm thinking there's got to be an easier way to figure it out...can anyone tell me how far forward or back they mounted theirs?...pictures would be good...
Old 10-01-2008 | 11:23 PM
J Lent's Avatar
I have the 150. It mounts on the inner frame rail about even with the tailhousing of the transfer case.
Old 10-02-2008 | 12:00 AM
bridleman's Avatar
X2 Make sure when you mount it that you have good clearance from floor board to top of pump motor, mine was hitting the motor when ever I hit a bump. I drilled three new holes in the mounting plate that holds the pump and filters about 1 1/2" down from the original holes. Now I have about 2 1/2" - 3" clearance from the floor board.
Old 10-02-2008 | 02:58 AM
Ed ke6bnl's Avatar
yep. then mount your pressure gauge you have one right. Ed
01blackspeeper
03-23-2012 05:52 PM
Tractor Truck
01-20-2011 02:56 AM
GlennRMK
04-15-2009 06:57 PM
kdbvulcan
20
12-06-2008 05:34 PM
madhat
08-31-2008 12:32 PM
