Where is the map sensor and data link????
Old 06-02-2008 | 08:15 PM
wrangler04's Avatar
Can anyone tell me where the data link and the map sensor is located on a 1999 dodge 2500? Pics?
Old 06-02-2008 | 08:19 PM
1badchopper's Avatar
Both on the drivers side behind fuel filter.Data link probably has a plug in it that doesnt go any where.The MAP sensor is the first sensor on the block behind fuel filter
Old 06-02-2008 | 08:29 PM
wrangler04's Avatar
I found 2 plugs that dont go anywhere but the data link wire wont work with either. Ive found a couple of sensors/connectors and the map sensor plugs wont work for either.
Old 06-02-2008 | 08:54 PM
wrangler04's Avatar
This is the map sensor right?
Old 06-02-2008 | 08:58 PM
Gunrunner's Avatar
Isn't the data link right under the steering column?
Old 06-02-2008 | 09:07 PM
wrangler04's Avatar
Looks like I was shipped the wrong quadzilla programer. Thanks for yalls help.
Old 06-02-2008 | 09:08 PM
wrangler04's Avatar
Im not looking for the OBDII connector. I was trying to install a Quadzilla Max Mileage. They sent me one for a 2002, I have a 1999.
Old 06-02-2008 | 09:11 PM
that makes sense
Old 06-03-2008 | 02:02 PM
smokinram99's Avatar
The DATA LINK on 99 is under the VP44! look at the interlaced wiring looms under the pump...you see the data link cableGREY connector(it's a big connector) with a CAP for protection. Remove the cap and plug in your wiring!
I have installed my EDGE EZ on my 99 2500
scottboy69358
07-04-2013 03:05 AM
Moobesor
02-23-2008 10:57 AM
Ridiculous
03-21-2006 07:58 PM
orcaburger
09-18-2003 05:43 PM
drecu
12-02-2002 05:28 PM
