where can i install these guages?
Old 10-17-2005 | 11:02 PM
blackdiesel's Avatar
Registered
alright, after blowing the trans outta my truck i think its time for more guages. if i would have had a few more guages, i woulda saved myself over 3 or 4 grand. where can i install a temp guage in my rearend and in my trans? yall might not think its necessary, but after replacing my rear end AND my transmission, i think it is. plus, they look cool.
Old 10-17-2005 | 11:13 PM
abbeyinc's Avatar
You might look at Westach Gauge. Geno's Garage sells them. Westach makes a dual-needle universal temp gauge. Hook it up one side for the tranny and the other side for you diff maybe?
Old 10-17-2005 | 11:30 PM
Registered
i was wanting z series to match my others
Old 10-18-2005 | 01:08 AM
piperca's Avatar
Tough!
Old 10-18-2005 | 01:12 AM
Dr. Evil's Avatar
How about this??....a digital guage - you can get a guage and two senders. Use a switch to toggle back and forth between the tranny and the diff. Youll find this will probably be your best and cheapest option:
http://www.jcwhitney.com/autoparts/I...D:100000183358
Old 10-18-2005 | 08:14 AM
Ben's Avatar
Ben
Blackdiesel,
I have my tranny temp gauge mounted down on the passenger side of the shifter console. I like it alot there. All it takes is a quick glance to check. I don't see why you cant mount 2 gauges there. When you have 3 people in the front or rolling old school with a female you just have to remind them that it's there and to keep their feet away from it.
Have had it there 3 years an no issues.
Old 10-18-2005 | 08:18 AM
Registered
im sorry i guess i didnt make it clear. where do i install them in the rear end and in the trans? in the cab im going to get a 3 dash pod, a column pod and ill stick one in the hole by the raido. thats a oil temp for the motor, air pressure, vacuum, fuel pressure, trans temp, and a rear end temp. humm.. thats six and i only have 5 holes. oh well ill come up with something. i just need to know where to stick them in the trans and rear end. Thanks alot
Old 10-18-2005 | 08:35 AM
Dr. Evil's Avatar
Originally Posted by blackdiesel02
ithats a oil temp for the motor, air pressure, vacuum, fuel pressure, trans temp, and a rear end temp. humm.. thats six and i only have 5 holes. oh well ill come up with something.
Thats why I recommended the digital guage with 2 senders - 2 functions to the guage and then you only need 5 mounting spots instead of 6.
Tranny temp guage goes in the hot line to the cooler and diff temp goes in an aftermarket (Mag Hitech) diff cover.
Old 10-18-2005 | 08:57 AM
getblown5.9's Avatar
id love to know what you were doing to take out a dana 80 rear and nv5600 tranny...did you drain the fluids and drive cross country?????
however it was you killed your tranny, it couldnt have been heat. i have a temp gauge on my 6pd and in 100 degree summer heat, running 6th gear on the highway at 75-80 mph, my tranny temps will MAX out at 150*
but to answer your question, invest in some FAST coolers for your tranny, they bolt right up, and have a place to screw in a temp sending unit right on the bottom of the cooler. and for your rear, if you did kill it with heat while towing etc...then invest in a mag hi-tech rear diff cover with the added oil capacity and a tap for a sensor built in. i mean it would be wise for you if you have already killed a tranny and a rear to take these steps and get some added cooling/lubricating capacity in these parts and the taps for sensors are built right in
Old 10-18-2005 | 09:08 AM
Registered
welllllll............... the shifter wansnt tightened down on top of the trans when i replaced the clutch, thus lettting all the fluid get out of it. so yes, i did drain the fluid and run across country. but if i would have had a trans temp, it would have read really really hot i would imagne and then i would have put fluid in it and this would have saved me round 2 grand. as for the rear end, it was bent on the drivers side, so the axel shaft wouldnt seal to the axel tube. so i had to replace the whole friggen thing.
Totallyrad
07-19-2011 08:41 AM
mx684
04-13-2007 07:23 PM
Andyinchville
11-08-2004 10:00 PM
Mark Thomas
08-12-2003 10:02 AM
MARKY MARK
11-27-2002 06:16 PM
