where can I get a set of these?-mudflaps
http://www.smoknya.com/My%20Truck%20...2003%20002.jpg[/IMG] I need a set of those flaps
Here:
http://www.powerstore.cummins.com/cgi-bin/powerstore.pl
Click on search in the upper right hand corner, select Apparel and Accessories, and type mud flaps in the box.
24" X 30" size with pre-drilled mounting holes.
2 black vinyl heavy duty 1/8" thick mud flaps with large white imprinted "C" logo. Hardware not included.
How can you make these work on a 2500? Seems like they are for 3500 because of the wider wheel well correct? I like them but would I have to cut them to fit on my truck? The pic shows it on a SWA.
Looking at the photo I have and the one from the Cummins site, the ones on the truck are a bit narrower on the side. Im betting a little alteration with a straight edge and a razor knife would do the trick just fine.
I just went out and measured my truck and there is noway those will fit on my truck. The shortest length they have is 30 and my truck is about 25" from the ground to the bottom of the fender. I know I can move them up but 24" wide? Fromt he inside of my wheel well to the outside of the tire it is about 16" So I just dont see how I can do this. Would it look good to cut it? Seems to me it would look bad. Those flaps are definately for a semi. I am going to email the guy that owns that truck and see how he did it. I know hes got a lift kit so his is higher off the ground but still, I dont know how they willl go on mine. I'll let you know what I find out.
Looks like he trimmed off about 2-3 inches each side.
Probably has some metal bracket made up for them to hang from or trimmed the top of them to more like this ones.
(also Cummins Powerstore)
The Big C ones would fit on my truck, lengthwise , alot better than the little Dodge Cummins ones.
I'm pretty sure I'll have to get some flaps before inspection time next March.
phox
phox
Originally posted by Cumminsdude
What email did you use? Theres like two. One for EEP and a hotmail one.
UnrulyNFS
06-27-2007 02:51 PM
jsflagstad
19
06-19-2007 02:05 PM
raven564
10-13-2004 04:40 PM
