where can I get a boost elbow?
I need a boost elbow... I guess... I know they come when you buy an EZ and stuff ... but I don't need the chip (Already have one) just need the elbow. So, where could I buy one?
Got mine from www.tstproducts.com
How about you make your own? There's nothing to them
http://home.att.net/%7Ejason510/ManualController.htm
or
http://www.xmission.com/~dempsey/perform/grainger.htm
or
Greenwing, look at your boost elbow and see if it is a solid tube or a fitting with a flex hose. I have a 2001 2500 and mine has the solid tube. Edge sells an assembly for that type of wastegate for around $50 that places a spring between the turbo and the wastegate to prevent it from opening until higher pressures are present. My kit came with the replacement boost elbow and I cant use it. PM me if you want it
Re: where can I get a boost elbow?
The best bet is a ball and spring manual controller for quick spoolup, and a small bleeder after it for boost sustain.
Test the ball and spring with a "migty-vac" to x-psi (make sure it doesn't leak), the adjust the bleed after it to hold that PSI until the next shift.
I made one for my supra using a adjustable regulator for a hvlp paint gun, just clip splice and set it where you want it, boost becomes totally adjustable and you will be out $10. my current truck "accidently" got poked in the wastegate line with an o-ring pick which misteriously brought my boost up
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
Common
05-23-2008 05:05 PM
dodgediesel
14
12-14-2006 09:54 AM
ramz
07-07-2005 07:06 PM
JBlackwell
11-20-2003 11:33 AM
