Where to attach line for FP gauge?
Old 09-26-2005 | 10:52 PM
Yukon Dodge's Avatar
I got my Isspro gauges from Rod at Wildcat Diesel, but he's no longer around ... so which plug do I remove on the top of the fuel filter: the one toward the center, or the one toward the outside? I think I want the pressure post-filter so I can monitor it going into my new pump. And the tubing he gave me is Imperial Impolene 22PY-1/8 NSF 51 MAX OPER TEMP 212F. If one of you experts on this could confirm that this is the right stuff, I'd sure appreciate it!
Old 09-27-2005 | 06:13 AM
crobtex's Avatar
If it's the same as my '99, it should look something like this. I don't know about the tubing.
Old 09-27-2005 | 07:04 AM
Shovelhead's Avatar
Administrator / Scooter Bum
That's a picture of my FP gauge setup.
The line is connected to the Post-Filter test port.
Old 09-27-2005 | 07:07 AM
crobtex's Avatar
I'm not trying to steal you patent. I just done a search and it was the best example I could find.
Old 09-27-2005 | 07:27 AM
Shovelhead's Avatar
No problemo.
Old 09-27-2005 | 08:04 AM
CTD NUT's Avatar
Here is a pic of my set up....the hard line with the needle valve is post filter that runs to the in cab gauge and the gauge on the filter housing measures pre filter pressure.
Old 09-27-2005 | 08:10 AM
Shovelhead's Avatar
Hey CTD NUT,
They make this wonderful product........ever hear of it?
Old 09-27-2005 | 08:26 AM
blackdiesel's Avatar
Registered
whats it supposed to look like on a 02?
Old 09-27-2005 | 08:39 AM
CTD NUT's Avatar
Hey CTD NUT,
Ouch! That hurts! The engine is a lot cleaner these days.....still working on getting it cleaner, though. After 230K + hard working miles and 7 salt filled winters, it needs a lot of attention....the previous owner did absolutely nothing to keep the engine bay clean. I guess I better post some pics when it's done to redeem myself, huh? Sheesh!
Old 09-27-2005 | 08:43 AM
crobtex's Avatar
Similiar, except it goes on the bottom of the filter housing. Do a search and you can find a pic.
Old 09-27-2005 | 09:16 AM
CTD NUT's Avatar
A tapped Comp and 130 hp sticks with no FP pressure gauge?!?!
Yikes....better get one right away!
On 00 and later CTD's, there are no provisions on the fuel filter canister to tap into for a FP gauge so you have get the correct fitting to screw onto the schrader valve test port on the VP44. The fitting is a #4 SAE fitting...it has a 45* flare but a 37* -4 JIC hydraulic fitting will screw and fit fine with no leaks as the pressure is too low to cause any problems.
Old 09-27-2005 | 11:11 AM
Shovelhead's Avatar
Some folks use a tapped banjo bolt under the fuel filter canister as their pick up point.
Old 09-27-2005 | 11:40 AM
Registered
yeah i know. ive been meaning to get one for 5 months now. haha ive got a new lift and vp44. i better get on it. autometer dosent make a z series 30 psi. so what one do i get?
Old 09-27-2005 | 09:41 PM
Thanks, guys! And yeah, I need to get some Engine Bright, too!
PapaPerk
01-10-2005 09:09 AM
HOdiesel
12-30-2003 09:29 AM
ramguy
12-03-2003 01:47 PM
Steve5.9L
09-29-2003 12:36 PM
TXTad
11-22-2002 12:35 PM
Quick Reply: Where to attach line for FP gauge?
