Wheels would like some info and advice......
As you can all see from my sig, the truck is very much as standard. unfortunatly some time ago i lost one of my center caps, and i have been told that one of my wheels is buckled, because it can not be balanced properley. I have tried to get a good second hand center cap and wheel here, but i'm not having a great deal of luck.
Now this is where i need your input. I have been offered a low milage set of wheels and tyres off a 2004 Ram 2500. they are 17" chrome steel 5 spoke wheels.
I thought that all OEM wheels on 3rd gens had alloy wheels. Does anyone have a photo of said wheels for a 2004.
My next question is, are the PCD,s the same on a 1999 as a 2004 bearing in mind they will be from a Canadian truck?
And finally, is the offset the same or do i need spacers, if i do what thickness of spacer do i need and will the standard wheel studs be long enough, if spacers are needed. ...Thanks, any info would be appreciated...Ade
mwbates
13
09-25-2011 11:21 AM
dcwm
10-05-2009 02:26 AM
dcwm
09-29-2009 07:18 AM
MmmDieselFumes
11-14-2007 06:21 PM
LeftLane
07-01-2006 08:25 PM
