Wheels for 315's
Old 08-02-2004 | 11:27 PM
OldSmokey's Avatar
Wheels for 315's
Just wondering what would be the best offset to run 315's with as little rub as possible. And how wide of rim. THanks
Old 08-03-2004 | 12:12 AM
BigBlue's Avatar
If I'm correct, a 4.5" offset is the preferred choice. Buddy of mine has a 16x10 rim with a 4.5" offset with 315/75/16's on them and he doesn't have any rubbing problems.
Old 08-03-2004 | 12:34 PM
gaRam's Avatar
Muted User
i would get a 16x8 instead of the 16x10. i currently have the 16x10 with a 2 inch spacer and 2 inch add-a-leaf, the wheels have the 4.5" backspacing and they rub very well at full lock. i am ordering a set of black AR-767's soon in the 16x8 with 5" backspacing. i've always heard that alot of backspacing is key to running big tires of the dodges. it was even in fourwheeler magazine a while back. they said with a 2 tp 3 inch lift you should be able to run a 35 with no rubbing issues with the right backspacing. i've heard all of this off of www.pavementsucks.com too.
Old 08-03-2004 | 07:38 PM
phox_mulder's Avatar
It's not that 4.5" is preferred, its standard offering from 90% of the aftermarket rim companies.
I think 5.5" on our Dodges would be optimum.
6.75" stock is really tucked under, resulting in control arm rub.
4.5" aftermarket really sticks out, and rubs rear inside fender.
5.5" would be the compromise.
I'd say 10 inch rim if you could find a 5.5" backspace, they look great with the 315's.
If all you can find is 4.5", then go with a 8" rim, you'll avoid most of the rub issues.
phox
Old 08-03-2004 | 08:13 PM
OldSmokey's Avatar
I am looking at the Michey Thompson classic locks and they have a 4in backspace would they work.
Old 08-03-2004 | 09:09 PM
What width?
4inch backspace on a 10 inch rim would have 6 inches of rim sticking out from the hub, and would have some serious rub on the rear inside fender.
4inch backspace on a 8 inch rim would only have 4 inches sticking out, and should be fine.
phox
Old 08-03-2004 | 09:22 PM
BigBlue's Avatar
I guess I'm gonna have to find a 10" wheel with 5.5" back spacing. I want the 10" wheel. Fills the wheel wells better.
Old 08-03-2004 | 09:25 PM
Get the 10".
Maybe they'll work just fine on your truck.
Mine don't rub daily driving, only on a hard right turn while stuffing.
phox
Old 08-03-2004 | 10:16 PM
OldSmokey's Avatar
I was thinking 16x8, or would the 10's be better.
Old 08-03-2004 | 10:24 PM
With just the leveling kit, 8's would be best.
Blue wants to go tall, so the 10's should work for him.
phox
Old 08-03-2004 | 10:31 PM
OldSmokey's Avatar
Thanks phox
Old 08-04-2004 | 04:13 PM
gaRam's Avatar
Muted User
i've had the 16x10's with 4.5" backspacing and it rubs. it is acutally chunking my tires up. i'm ordering the ar-767's in a 16x8 with 5" backspacing. i believe that will be optimum for me because it shouldn't scrub and i am also deciding to go to a 285 from a 315 because fuel is expen$ive. hopefully i can gain more mpg with a smaller tire.
tontof18
09-28-2006 08:59 PM
rjordan
09-27-2004 10:25 AM
VPI
01-13-2004 07:37 PM
thecatsfan
12-30-2003 11:44 PM
