Whats the part number for the Headgasket I need and do I have to mill my head
Old 01-04-2005 | 12:50 PM
Dufrain's Avatar
Well my head is leaking on the passenger side in the normal problem spot.I have searched and read and still dont know which head gasket to get.Maybe the marine one or what about the copper one.Can someone tell me where to order the one I need ,maybe from a site sponsor.I need the part number also.
Do I for sure need to have the head milled and can a local shop do it .
Is there a procedure online somewhere .I looked all over dodgeram.org and on google.I have done gas heads before but not a diesel.
It looks like to me ,just pull the intake,injection lines ,take the exhaust pipe loose from the turbo and the rocker arms and pushrods and headbolts and it should come out.
Id like to leave the ex manifold on it to keep from fighting it.
Thanx for any help.
Old 01-04-2005 | 06:18 PM
INJECTOR JACK's Avatar
You can unbolt the manifold and leave it attached to the exhast pipe the turbo and manifold will stay in place.Remove your fuel lines and injectors but you can do that after if you like.
Remove all wiring and piping don't forget the temp sender wire at the back l/h corner of the head. Remove valve covers and valve train. 2nd gens have holes with plugs in the cowl above the rear rocker arms. Remove plugs and push the push rods threw the holes this is the only way to get them out. Make sure you put the push tubes back into the holes before you put the head on or you won't get them back in. Make sure coolant is drained including the block.
Unbolt the head and remove. Find a machine shop that does diesel engines make sure they are good , the head is a high $ part to replace for a screw up. As for the head gasket you will have to get a thicker one that matches the amount plained off. I'm still wondering what gasket to use myself? I'm leaning towards a marine gasket. Good luck.....Jack
Old 01-04-2005 | 08:31 PM
Dufrain's Avatar
What are the push tubes you mentioned and can I get away with leaving the ex manifold on the head ,Im worried ill have trouble getting it back on with the shrinking they talk about.Is there any thing to tell the machine shop on the way it need to be milled or does it for sure even need milled.thanx for the help
Old 01-05-2005 | 11:43 AM
The push tubes are the push rods. You are going to have to remove the exhuast manifold to get the head surfaced. I didn't have any problem bolting it back after I removed it. I would plain the head I didn't and a few months later the gasket leaked again in the same areas as yours.
Old 01-05-2005 | 12:05 PM
Dufrain's Avatar
ANyone have the part number for the gasket or know if any of the sponsors here sell them
Old 01-06-2005 | 01:00 AM
halerazor's Avatar
http://www.scheiddiesel.com/cummins_engine_parts.htm
they have the marine gaskets same price as the stock gasket less than $90
Old 01-06-2005 | 01:03 AM
Dufrain's Avatar
thanx alot
SKATERHAULER
09-02-2011 04:46 PM
77machomopar
01-24-2008 06:30 AM
Hawthorne
12-11-2007 08:37 PM
gunracer1
09-25-2004 03:52 PM
Stamey
06-02-2004 08:24 AM
