whats that mean?
The comp box is rated at 120hp on it's highest stage. In order to get the full 120hp, you have to splice into to the injection pump wire so the comp will manually make it deliver more fuel. If you do not tap the pump wire, it will run just like an ez box and only give 65hp. The box will not deliver any more power on any stage above 2. The power will come on quicker but thats it. To get more info on it, you can go on www.edgeproducts.com .
Tapping the wire is like walking on the darkside. Once you do it, you never come back. Make sure you are ready for the commitment to tapping the wire. You will never be the same afterwards.
Tapping the wire is like walking on the darkside. Once you do it, you never come back. Make sure you are ready for the commitment to tapping the wire. You will never be the same afterwards. Personally, I have not done it. I have grandkids and I want to be able to see them grow up.
The choice is yours. Choose wisely.
(Geeez, I'm starting to sounds like Beagle1).
DuaneWKKC
07-26-2006 12:25 PM
