Whats the difference in 3kgsk and 4kgsk
Old 11-13-2004 | 11:39 AM
Forrest Nearing's Avatar
I've never reached the point where mine defuels!
I'm curious... why does your '96 have a 160 pump?
FWIW, if I had a 160, I wouldn't even consider the 3k, just the 4k
Old 11-13-2004 | 12:35 PM
Rganser's Avatar
Another stupid newb question, but when does the stock GSK start to defuel, the one i test drove felt like about 2700 rpms
Ryah
Old 11-13-2004 | 01:36 PM
Dufrain's Avatar
I think the stock springs defuel even lower that 2700,i can really tell with the 10 plate and stock springs it feels like about 2400 or less on mine.
Hey Forrest
My 96 has the 160 pump because before I got it someone had replaced the motor with a low miles 95 auto motor,the dumb tps is still on there.I need to pull that thing off and sell it.I think Ill sell the 3gsk I have and order a 4.Why do you think the 4gsk works with the small pump better,is because there isnt as much fuel .thanx
Old 11-13-2004 | 01:47 PM
you don't have to sell your 3k... just call Piers and get the additional springs to make your 3k a 4k
the 4k works better w/ the 160 pumps because the 160 pumps defuel so early... so whereas on a 215 pump, a 3k setup will allow you to see 3300-3400 or so, on a 160 pump, you might see 2800-3000. make sense?
it gets fun up in the 2800-3500 range
Forrest
Old 11-13-2004 | 03:35 PM
Dufrain's Avatar
cool ,thats the plan then
Old 11-13-2004 | 05:13 PM
Rganser's Avatar
a 94 is a 160 pump, correct? do they just swap out or is anything different?
Ryan
Old 11-13-2004 | 05:35 PM
Dufrain's Avatar
any of the 94-98.4 pumps will interchange.the 160 pump is 94-95 automatics
Old 11-13-2004 | 05:41 PM
Rganser's Avatar
so what would a 94 manual be? sorry I am picking up a new truck wed. and am just curious
Ryan
Old 11-13-2004 | 06:07 PM
94-95 = 160
96-98 auto = 180
96-97 5sp = 215
Forrest
Old 11-13-2004 | 06:57 PM
Rhino's Avatar
Forrest you have to make a correction to your chart.
1994-1995 auto are 160 pumps
1994-1995 manual trannies are 175 pumps
Old 11-13-2004 | 07:25 PM
Rganser's Avatar
So, still not a definate answer i guess, what about a 94 manual??? I assume 160? Is that what the pump is from the factory, or is that what is is capable of? The one i am getting has been turned up already.
Ryan
Old 11-13-2004 | 07:28 PM
jtb51b's Avatar
When you guys added a GSK kit, what kind of top end speed do you see? I have only ran mine up fast once but I got to 95 and still had fuel left (or so it felt). At that point my tach was sitting about 2300-2400. Thanks for your time.
Jason
Old 11-13-2004 | 07:40 PM
Rhino's Avatar
Ryan,
I fixed the typo in my original post. Sorry.
Old 11-13-2004 | 09:39 PM
Rganser's Avatar
Cool, thank you very much!
Old 11-15-2004 | 06:00 PM
cumminsdriver635's Avatar
Well with my GSK, and 160 pump with a fuel plate, mine pulls to about 3k hard, and will go to about 3300rpm's, but i need to do timing because it wants to start popping after that. If you hold it in first or something though, it will jump right to 3300rpm's. The difference in the 3k and 4k is that the 4k has 1 more small spring that goes on the inside of the springs that came with the 3k kit, and then you need the heavy duty valve springs.
Autos:
94-95: 160hp
96-98: 180hp
Manuals:
94-95: 175hp
96-98: 215hp
Eric
96 Ram man
01-23-2008 11:24 PM
wcbcruzer
06-02-2007 10:15 PM
Teddy Bear
07-21-2006 03:55 AM
condensr
04-11-2005 02:04 PM
Weg
09-12-2004 01:08 PM
