whats the best towing twins?
Old 04-03-2006, 08:21 AM
RowJ's Avatar
If I follow what you guys mean by spacer... the kits now have one.
BD's web site lists and new (bigger) set coming out very soon... with an S400 on the bottom. Should be sweet if the R&D is as good as on the first set.
RJ
Old 04-03-2006, 09:30 AM
Mike D's Avatar
I was following Matt's truck on the way home after the install. His truck is whisper clean once boost comes up. Correct me if I'm wrong Matt, but I think you said that was on 5x5. It will smoke for about 2-3 seconds then nothing comes out the tailpipe. His truck will jump me on the highway at a roll. I had to bump my TST up to 2 just to hang at his door.
Old 04-03-2006, 04:59 PM
70crewcab's Avatar
The Ht3b-26 is perfectly matched to the hy/hx's that are common on CTDs.
The HY9 can be used on top if properly wastegated and be capable of the 550 hp that the BD twins claim to make while spooling like a rocket.
If you want more power then just swap out the hy for the HX35-12. From there a 40 compressor then finally a 14cm housing. This setup is capable of 645hp on a daily driver. I have a customer that's been doing it for 3 years.
Boost is controllable from 30-70 psi based on wastegate adjustment.
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
dodgediesel
17
04-05-2011 11:21 AM
PowerDually
06-18-2007 02:22 PM
Stock 02
28
09-24-2006 11:09 AM
Quick Reply: whats the best towing twins?
