what are YOUR temps?
I am curious and want to compare. What is your EGT and boost level at 60 mph in OD not towing and not going uphill?
mine today is at 15psi and about 900 degrees.
Cruising at 60? how does one get that slow, gearing?
Speed limit here is 65, most traffic is between 70 and 75.
Most of my cruising is at 70,
boost right around 10-12,
and EGT right around 800-900 deg.
RPM's around 1700.
I've found if I try to stay with most of the traffic, my fuel mileage plummets, so I keep it at 70ish.
Ok, you probably wanted more of the undervalved crowd to answer.
I bet you have a 4.10 rear end.
phox
RPM's around 1700.
phox
Cruising @ 70
-6-8 pounds of boost
-EGTs about 650-700
going up any hill the EGTs will move up to about 800-900, with about 15-18 pounds of boost.
-EGTs about 650-700
700* at 60 mph...800* at 70 mph.
Boost...level ground....I get 3-4 psi.
Lance - Your boost/temps sounds high, even for stock turbo...maybe it's the lift?
RJ
RJ
yea I was thinking the same thing. although with the 40s and the 410s, my speedometer is only behind about 2.5 mph at 60. I guess its the increased wind resistance.
