What year is this truck?
I am trying to put an EZ on my dads supposed 2000. I don't know if the year model is different on the Ez or the truck is not a 2000. It has a manufacturing date of 7/99 with a 235hp at 2700rpm with 6spd. One sounds like a 99 the other sounds like a 2001. The vn#1B7MC336IYJI03203. The first 0 might be an alphabetical O instead of zero.
Registered
well if the ez is for a 2002, and it wont fit, then the truck might acually be a 2000. because they are all different. sorry, i dont know the vin decodes that well.
![Frown](https://www.dieseltruckresource.com/forums/images/smilies/frown.gif)
The Guru
You can get an 01 or 02 truck to run an 01 or 02 box. An earlier box, its not suppose to work that well. You can get adapters to make this to work as the sensors change thru out the years as cummins couldn't make-up there minds on what to use.
Originally Posted by OutlawStorm
The truck is for sure a 2000 the 10th digit is a Y and that for sure makes it a 2000
http://dodgeram.org/tech/specs/VIN_decode.htm
horsinaround
04-14-2012 06:35 PM
trophystock
07-16-2006 11:00 AM
