What will I gain going to COMP?
Old 01-11-2005 | 12:00 PM
CTD_Neil's Avatar
What will I gain going to EDGE COMP?
Hi. I recently installed some DD3's in my truck and love 'em! The power change is quite a bit. I currently have the Banks kit as seen in my sig. I don't believe the fueling with the Ottomind is as agressive as a COMP, is this correct? People with Edge COMP setups seem to be fueling alot more than I am. I can get it to smoke pretty good, but when boost comes above 25-30 lbs it just a light haze. Will going to a COMP box gain me more power? I may consider the new Banks BigHoss upgrade also so I can contiue to use my gauges, ANy body running one of these? How does the COMP compare to to the Banks Ottomind and BigHoss??? Thanks --Neil
Old 01-11-2005 | 01:57 PM
BigBlue's Avatar
The comp box will add 120hp to the wheels set on 5x5 with the wire tapped by itself. I don't know much about the banks stuff, but with the comp, you'll get on the fly adjustability for your power levels, plus, you can control the low end fueling on each level. Plus, since you don't have a clutch yet and 5x5 with DD3's will definately kill it, then you can leave the wire uptapped and it will act just like an EZ and only give you 65 hp.
Old 01-11-2005 | 02:27 PM
pmtg's Avatar
But its going on an ETH so you should only expect about a 95hp increase. Which is something to lookout for when researching the Banks, make sure the power claims are coming from a ETH motor. Do the Banks defuel according to EGT's on the 2nd gens? The Comp will defuel @ 2700rpms but not because of EGTs, the drag Comp however will not defuel.
I really liked the Comp on my truck with its adjustability in power and smoke, but have no base of comparison as I never tried any other fueling boxes.
I wanted to try a Blue Chip Diesel's Redline box just because I havent heard much on them, could be a bad thing though. But to wind up to 4000rpm would be fun.
Pat
Old 01-11-2005 | 02:46 PM
Kyle Graham's Avatar
You will notice alot more smoke and power with the edge comp or drag comp it is a whole diffent animal than banks ottomind
Old 01-11-2005 | 03:28 PM
CTD_Neil's Avatar
Thanks, guys I think a Comp is in my future! Pat, still have yours for sale? lol
Old 01-11-2005 | 05:00 PM
ratsun's Avatar
With DDIIIs and a Comp your gonna know the meaning TOASTY so I would set aside some $$$ for turbo work as well as your clutch
Old 01-11-2005 | 06:13 PM
CTD_Neil's Avatar
Right now my ottomind de-fuels to keep the EGT's below the limit, so I don't know what hot is What kind of temps are we talking about? and what kind of dyno numbers could this combo produce?
Old 01-11-2005 | 06:23 PM
ratsun's Avatar
Cant tell you the HP #s but with the Comp and DDIIs I hit 1500 right fast I'm not sure but I think your turbo is different then mine so.....
Old 01-11-2005 | 07:37 PM
Bob Wagner's Avatar
are you close to santa barbra?
Old 01-11-2005 | 08:44 PM
CTD_Neil's Avatar
I'm in Northern California (St.Helena)! If you were asking me.
Old 01-12-2005 | 01:06 AM
Clunk's Avatar
Don't forget your lift pump pressure guage.
Old 01-12-2005 | 09:13 AM
CTD_Neil's Avatar
Yah I am going to add a fuel pres gauge soon.
Sidewinder
05-29-2004 12:20 AM
iwantaCUMMINS
04-09-2004 05:48 PM
j
01-09-2004 09:19 AM
dma251
09-21-2003 07:22 AM
