What tuner?
Old 12-29-2008, 05:40 PM
1998dsmtalon's Avatar
What tuner?
I have a 2001 Dodge Ram 2500 4x4. It already has a 4 inch exhaust, K&N drop in filter and a FASS Fuel system.
Which tuner out there is going to give me the best results and give me the most gains.
Old 12-29-2008, 06:00 PM
Ron R's Avatar
old skool drag comp?
Old 12-29-2008, 06:02 PM
lvmknsmoke..'s Avatar
x2 edge comp
Old 12-29-2008, 06:03 PM
A buddy of mine with a 03 powerstroke has a ECM reflash instead of a tuner.
Is that possible with these trucks?
Old 12-29-2008, 06:30 PM
97 D-Tec's Avatar
it may b possible but imo the programmers n etc. that are out for these trucks (all trucks in general) are much better because you get a choice. you get to choose how much power you want and when you want it. A ecm reflash just cant do that i dont think
Old 12-29-2008, 06:38 PM
Moules's Avatar
Drag Comp! ther dirt cheap right now in the classifieds and they put out as much power as any other box out there. cant beat that.
Old 12-30-2008, 12:20 AM
Flatbed24v's Avatar
drag comp stacked with a smarty and it looks like you could use some gauges!!
Old 12-31-2008, 08:02 PM
I have a FP gauge as well as EGT and boost.
Not sure about all the lingo yet, but what do you mean stacked with a smarty?
If you mean exhaust stacks then no way. I cannot stand them.
Old 12-31-2008, 11:35 PM
psd tuner's Avatar
you will def. want to go with the smarty. very pleased but is pricy. ya get what ya pay for. well a drag comp is a fueling and i think a timing box, the smarty is a downloader. the comp plugs in the factory map sensor and the connector the controlls the injection pump and fools the ecm. i think. the smarty reflashes so to say the computer. so running both of them should give you a little extra get up and go. so basically you run the smarty and the drag comp at the same time and that would be a stack. BUT YOU CANT RUN THE SMARTY TUNES WITH TIMEING WITH A TIMEING BOX
Old 12-31-2008, 11:45 PM
nickg's Avatar
My vote is for the Edge Juice with Attitude It is simple to use and lets you monitor all the engine vitals, allows you to set alerts, and it will defuel the engine should you exceed safe parameters. or get the adreline which has even more features
with the stuff in my sig the monitor tells me my 0-60 time is 5.7seconds not too bad for an 8800lb truck!
Old 01-01-2009, 02:51 PM
I am leaning towards the Edge Comp to start off with then maybe in a few months, I will add the smarty.
I might be replacing my lift pump first so well see how the wallet is after.
Old 01-01-2009, 05:19 PM
Flatbed24v's Avatar
ya for sure upgrade your fuel system first
Old 01-02-2009, 05:00 PM
It has a FASS fuel system installed by a Dodge dealer as per the previous owner but I am not entirely sure what that is or what it does.
Old 01-02-2009, 05:12 PM
Tate's Avatar
If it really has a FASS on it, no need to replace it, thats one of the better options on the market. Make sure it has one though, pump would most likely be on te drivers frame rail near the tank. A true FASS will have two filters and the pump above them, although there is a HPFP, which is just a stand alone pump, no filters.
Old 01-02-2009, 05:56 PM
I don't have a filter. But it is on the frame rail right on the drivers side about middle from the drivers door to the rear wheel.
What does it do?
Quick Reply: What tuner?
