What is a Smarty
Originally Posted by phox_mulder
Search is your friend.
phox
phox
Thanks
If you do any sort of performance mod, you need gauges, and if you have gauges you can tow with pretty much any sane setup, as long as you watch EGTs.
If you are pushing 500 hp on a single charger towing will be rough, because when towing low end power and low EGTs are your friends, and from eveything I hear those are the two things the Smarty does best. Plus it gives you 9 settings, surely one is what you want. Only towing 7k, you ought to be able to load #9 and tow all day.
Towing with a smarty is a dream. I have 2 trucks 1 with a catcher (#9 smarty) and large injectors and its a power house pulling a 15k trailer. with a stock auto it might kill it because of the huge low end power the smarty gives . I like towing with it, but you might want to do a valve body change to the auto to start and maybe a TC also
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
CTD_Neil
02-23-2006 09:27 PM
