What size Airdog
Old 05-17-2009 | 05:36 PM
HidalgoGT's Avatar
What size Airdog
I plan on running 200-250hp injectors along with the mods to make them work sometime this year but, I figure I will start with the clutch and fuelpump. Buying the 150 would not harm my pretty much stock truck now would it? I don't plan on it taking me to long to start getting some good mods for it vs whats in my sig. Soon as I sell the mustang I want to buy a clutch and start getting goodies. Is the 150 the best choice when I want to put down 550ish to the ground?
Old 05-17-2009 | 08:02 PM
badme's Avatar
I run a 150 on my "pretty much stock truck" and I do not have any problems with it. I just filter my fuel a lot.
Old 05-17-2009 | 08:04 PM
J Lent's Avatar
150 for sure.
Old 05-18-2009 | 01:31 PM
J Lent's Avatar
Originally Posted by AirDog
It is not going to hurt anything running the 150. It will return more fuel back to the tank than the 100 is all. But... Unless you plan on going over 550 hp or p pumping the truck down the road. I would just run the 100. It is plenty on a vp44.
Thats the thing, we never plan on going over a set number....until we get there. I originally wanted 350hp, then it was 450, then 500. I hit the dyno & got 534, now I'm approaching 600. I'm gonna keep going until I see that the truck isn't towing my equipment like I want....then back it off a little. My advice is to always plan bigger than you originally think will be enough.
Old 05-18-2009 | 09:13 PM
HidalgoGT's Avatar
Well 550 to the ground would mean more at the flywheel. I dunno the ratio lost threw a 5 spd and transfer case as I am used to a mustang and gas motors. It was like 10% unless you lightened up the driveline rotateing mass. Course with the torque these monsters put out when lit up I wouldnt want to lighten **** up. My plan is 200 stix, aurora 4k or twins using my stock as the pusher. Still undecided on which stack to run tuner wise. Edge comp/tst comp/adr with the smarty. I want 500-550 to the ground. Soon as the car is sold the clutch will be in to support it and I'll be ordering a fuel pump this weekend. Truck is ready for enhanced inspection this weekend as well so I will be driving it soon can't wait.
Old 05-19-2009 | 01:28 PM
HidalgoGT's Avatar
Here how bout this. An AirDog 100 will handle 95% or more of all vp44 trucks out there. I dont believe you will ever out grow a 100 with a vp. So unless you plan on p pumping. I suggest the 100. We made 667 on fuel with a vp and an AirDog 100. Fuel gauge sat at 18 psi and pulled down to 17. That should clear it up.
Thats knowledge I like to read. I thank you much for it as well. Lots to learn about these. I used to be a powerstroke guy but, I wanted to make power and be reliable at that.
Brad5502
10-10-2012 09:49 PM
01blackspeeper
03-23-2012 05:52 PM
Tractor Truck
01-20-2011 02:56 AM
ekk33
01-01-2009 08:39 PM
kdbvulcan
20
12-06-2008 05:34 PM
