what should boost be??????
hi ive got a stock 2001 5spd,i installed my boost and fuel presure and pyro the otherday.the boost at hiway speed shows 2-4psi and 6-8 during shifts at 2000 rpm.it does go up and down when i step on it in 5th.up hill i got it to 20 when i matted it.0 at idle and maybe 2 when reving in driveway. do these# sound ok?i checked all boots and clamps and manifold bolts and checked wastegate operation.everthing seems ok. help???????????
Normal boost #'s should be:
6-7 psi @ 65 mph level ground
20-21 max WOT
This being said your highway #'s look a little...... but remember that if you are not at a constant throttle and on level ground the boost will be different.
Doug
20-21 max WOT
Doug
You should fill out your signature, to better help answer your questions. As for your boost levels, they look normal to me. Really, your doing good with 20 psi in 5th. Stock trucks average is around 19 psi. You seem to be disapointed with your boost levels. The reason you dont see higher boost all the time is because boost is the result of heat from the fuel burning in the cylinder. Heat is boost. You do need RPMs too. But that is why WOT in N wont get you any more than around 2 psi.
gscoker
16
02-17-2013 01:52 PM
turbomike
12-03-2007 09:31 PM
tywebb3
06-23-2006 11:30 PM
