What programer should it get with stacking to a edge comp
I have an Edge comp chip on my 2002. i am looking into programers. what programmer should i get and does it work to stack a chip and programer together. please help me on this.
So Getblown5.9 came over to my store tonigh and let me try the Smarty.
He's like just put it on #8. Take it for a spin.
Holly smooly, i smoked out the parkin lot and took off like a bat outta h.
that thing is unbelieveable, i had my comp on 3x5.
I just can't get one until i get a real tranny to handle the power.
Under lite throttle there was so much power, goin about 30 and givin 1/2 throttle i think the back duals broke loose.
I WANT ONE!!!!!!!!!!!!!!!!!!!!!!!
the difference between the Smarty is like having the Comp on and stock, it's that much power.
You can only run one form of timin.
For you it's the comp because you can't turn the timin off, it's made into the box. The smarty will add more (alot more down low) and add the catcher. I really don't understand what the catcher is but I finally rode in a truck with a smarty and man it worth every penny.
I think that on the Smarty that if you already have a timing box, Like Comp then you should only run the even numbers.
I know it blew me away with the power it gave my truck set on #8 w/ comp on 3x5.
I didn't believe all the hype but now
I IS A BELIEVER!!!!!!!!!
bwarning01
15
08-24-2007 10:19 PM
mx684
13
07-24-2007 08:52 PM
dbossdiesel
05-18-2007 10:05 AM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
