At what point to I need FASS
Old 10-17-2006, 07:51 PM
johnsjas's Avatar
At what point do I need FASS
I have been giving it some thought and I want to send my 160 pump out to get some mods done to it. Make it just scream! I was wondering if I will need to junk my stock lift pump for a fass system. If so should I buy just the pump or the hole filter system.
Old 10-17-2006, 08:00 PM
BigBlue's Avatar
On a 12v there's really no need to upgrade the lift pump. Yall have the holy grail mechanical pump that us 24v guys wish we had.
Old 10-17-2006, 08:03 PM
johnsjas's Avatar
Even if the injection pump has been moded (cam, pistions, ect...) the stock lift pump can keep up?
Old 10-17-2006, 08:07 PM
BigBlue's Avatar
Yup. It builds pressure as RPM increases.
Old 10-17-2006, 08:09 PM
johnsjas's Avatar
Alright that makes sense. Thanks for the info
Old 10-17-2006, 08:57 PM
wana12v's Avatar
I have asked this very same question, but the short answer is no it cannot keep up on a serious pump. if you have them do a cam and 13mm p&b it will have the ability to move alot of fuel. What alot of the puller use around here is the aeromotive a1000 pump and I may be using one in the spring in a fuel system.
also pressure is not volume even if the pump kept up you still have stock sized lines.
Old 10-17-2006, 09:03 PM
Smooshy's Avatar
Tru
Old 10-17-2006, 09:42 PM
PourinDiesel's Avatar
I would advise a FASS for heavily modified 12V engines due to the simple fact that you receive the benefit of fuel that has had the air removed from it. This could help with injector pump life in...especially in the higher rpm's.
Old 10-17-2006, 09:47 PM
Forrest Nearing's Avatar
not so true... I've heard about 500rwhp you'll definately benefit from an upgraded fuel system...
Old 10-18-2006, 07:45 AM
plow's Avatar
Not needed unless your over 600 HP.
Old 10-18-2006, 04:58 PM
Jambbii's Avatar
Well has anyone done testing? I think I may need to upgrade my fuel system,but who is right?
Old 10-18-2006, 05:22 PM
Diesel-Dan's Avatar
I feel that the FASS 150/90-1010@45 PSI or FASS 150/180-1010@45 PSI would do very well for anything. Stock included. You get 2 massive fuel filters (50,000 mile life), air separation, 3/8" line (Can be run with 1/2" if wanted.....but i don’t think its needed) and a strong pump with a 1 year standard wnty. (4 year if you send in your paper work to us)
Old 10-18-2006, 07:08 PM
johnsjas's Avatar
I am over 600hp.
Diesel-Dan Would it be advisable to buy just the pump and use the stock filter
Old 10-18-2006, 07:54 PM
wana12v's Avatar
i would personally want their filter setup for the ease of changing it, but also im not sure how the stock filter setup would deal with a big pump feeding into it and it would also seemingly become a restriction.
Old 10-18-2006, 08:14 PM
plow's Avatar
Originally Posted by johnsjas
I am over 600hp.
Then you should get one.
Quick Reply: At what point to I need FASS
