View Poll Results: What oil to run in a built transmission?
Mobil 1 Synthetic ATF
8.33%
Amsoil
29.17%
Royal purple
8.33%
Redline
8.33%
Mopar ATF+4
20.83%
Valvoline durablend
0
0%
25.00%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
What oil to use in new transmission
It's just about time to change transmission oil, but I'm not sure what oil to use in an aftermarket trans. After spending countless hours with the search function I still came up with nothing. I've always ran Mopar ATF+4 in the stock, but is there something better for a built transmission?
My tranny guy (a GM and Chrysler certified reman.) told me nobody makes any better fluids than Amsoil. I have it in my truck for all the oils and rear end grease and everything works great! They have a new fluid made especially for the NV4500 and NV5600.
If it was a stock transmission, it would be ATF +4. Thats because of the materials used in the bands and clutches being different than what other manufacturers use, and the oil needs to be compatable. But as the others have said, ask the guy who built the trans. Regardless of whats "best", find out what he says. After all, if something goes wrong with your trans, hes the one you have to talk to. Do you want him to say that its not covered because you used a fluid that he didn't approve?
Jim
Jim
I smoked quite a few transmissions using amsoil. Don't get me wrong, i think its the best oil/lube on the market, but not for transmissions.
If it was so great don't you think Dodge would of spec'd it for use in the stock transmission. It might have prevented them from paying out millions in warranty claims for the 47RE.
I also used Allison Transend. Had the same affect as the Amsoil.
Mopar ATF 3 and 4 are the exact same except for the heat rating. One can take more heat and still keep its properties the same.
I run amsoil in the diffs (netted me a 1 mpg increase) and amsoil in the t case.
Just regular atf 4 in the trans and delo in the motor.
Justin
Justin
Originally posted by Charlie8301
How much fluid does the trans and TC hold?
If your TC came with bolts in the box USE THEM. They are a different length then the stockers and are used because the billet front cover holes are drilled/tapped shallower then the stock welded lugs.
Justin
Wobblin-Goblin
04-01-2008 10:43 AM
morkable
11-20-2007 01:36 PM
bocuso
27
01-18-2007 12:54 PM
