what kind of mpg from hub convertion?
if i can ever get ahold of ems im going to order the hub convertion kit and the CAD delete kit. one of my buddys is thinking of haveing my order him the same thing but hes more worried about milage then any of the other binefits. anyone done it already and have some feedback on what u gained?
I have ran other vehicles (not my 24V) with hub disconnects and without, and with front and rear half shafts removed altogether and noticed zero difference in fuel mileage. I think most of such claims are perceived changes, not real: people start driving a bit less aggressively and think the change is due to the hubs. I would dare say that strong wind would cause more change in the drag of these trucks than the hubs.
-P
-P
-P
-P
i would say the increase in mileage is because the existing bearings are worn out. when you install the hub conversion kit the new bearings are what increase your mileage, not because you are eliminating the spinning of the drivetrain. you could very well see the same mileage increase by replacing the unit hubs with new ones because they contain new bearings.
i dont think it'll hurt, but unless everything you do is stop/go (accelerating the mass of that drivetrain) you will see very minimal increases on the highway...that is, if you see any increase at all.
just my inexperienced $0.02
ya i tow so the 2 low would be nice, i also dont like that my 4x4 realys on a vacum line. i do do alot of stop and go to so... guess ill just have to see what i get if emc off road ever gets back to me...
I don't have the CAD, so there's not that much advantage to me for a free-spin hub conversion.
I don't think the drag of the front axle is that much with a good lube. I actually prefer to have the front axle spinning, as it circulates lube and keeps seals conditioned and prevents rust on gears and such. It also helps remove moisture by increasing the operating temp of the diff up front to a more appropriate temp.
I get 20mpg most times with the front axle always engaged-- so how much better could it really get?
I gotta say, though-- my mileage hasn't been so hot since I got my truck back. 16.7 hwy from Bismarck to Fargo, and 18ish from Minneapolis to Chicago. But that's cold weather, brutal crosswinds, and winter fuel for ya..
jmo
jmo
12valveford
13
09-20-2006 10:59 PM
