What kind of boost of you seeing?
Old 04-30-2007 | 11:11 PM
curts99's Avatar
32-35 with my htt 62/14 should i be seeing more?
Old 04-30-2007 | 11:21 PM
inline6power's Avatar
i would guess atleast 40 with your mods in your sig
Old 04-30-2007 | 11:48 PM
JSPulliam21's Avatar
30 with a stock turbo and 75 horse nozzles
Old 05-01-2007 | 08:05 AM
wirewelderdude's Avatar
Have yall plugged your wastegates? With just my juice/attitude i can make 39#'s of boost. I know i should't have my wastegate turnbuckled, but its about the cheapest route to go. You may also look at your boots to see that all the clamps are tight and the boots are in good condition... I worked on one truck where the truck was only making 12# of boost, but after i found that a boot had come loose i fixed it and it almost made 40# of boost. Another thing is that each truck is different and you may be where you need to be.
Stephen!
Old 05-01-2007 | 08:20 AM
74dart's Avatar
The guy who built my turbo welded the wastegate shut because the few mods I have dosen't need it. When the 4gsk and new DVs go in then I will hook it back up. It will go higher than 40 but I don't let it.
Old 05-01-2007 | 08:43 AM
I have a boost elbow that is almost all the way open.
Old 05-01-2007 | 12:31 PM
6WHEELER's Avatar
I have a stock turbo, waste gate disabled, mach 2 and drag comp on 1-4,
35 to 38psi playing around, touched 40psi once.
I need more air.
Old 05-01-2007 | 05:35 PM
adidasman23's Avatar
Originally Posted by inline6power
really? wow, i hit 54-56 almost everday with my SPS 62/71/14 and i have hit 59 with it if i shut the wastegate all the way. have it wastegated now at 52. with my old SPS64/14, i was only able to hit 53 with the wastegate shut and everything on.
how do you adjust your wastegate. do you turn the wastegate in or out.
Old 05-01-2007 | 06:34 PM
turn it it. the more you turn it in the more it blocks the boost going to the wastegate. i use to have the allen screw type then i made an adjustable one with a T handle valve on it. works good.
Old 05-01-2007 | 11:11 PM
hey do you have any pictures of that setup???
Stephen!
Old 05-01-2007 | 11:52 PM
Stephen!
yeah i will take one tonight when i get home and either post it tonight or first thing in the morning
Old 05-02-2007 | 12:15 AM
Sweet, Thanks man
Stephen!
Old 05-02-2007 | 03:29 AM
BigBlue's Avatar
PS62/12 and I've got the wastegate set at 48psi. With the water/meth activated it'll tickle 50psi. I've had it as high as 55psi.
Old 05-02-2007 | 09:12 AM
here is my turbo
Attached Thumbnails What kind of boost of you seeing?-cimg0740.jpg   What kind of boost of you seeing?-cimg0743.jpg
Old 05-02-2007 | 11:51 AM
here ya go. i paid 29 bucks for it but you can go to home depot and get one just like it in the pipe section for 10 bucks.
