What injectors can I use w/ stock turbo?
Old 05-25-2006 | 11:38 PM
JD farmboy's Avatar
I am thinking about putting injector's or maybe replacing nozzles, I'm not sure, I'm kinda new at bombing. I was wondering what size injectors (or nozzles) I can use with my stock turbo. I am now running an Edge Comp and a stock air filter box and exhaust system w/ a straight pipe. I would be replacing the air filter box with the Scotty II and maybe going with a 4" MBRP or maybe stacks, before I put injectors in, but I'm just looking around and pricing and kinda tossing the idea around.
I pull a 25' gooseneck, sometimes heavily loaded, so I don't want to do anything that will raise my egt's too much, but I'd like to maybe get more power over and above the Comp and Scotty.
Old 05-26-2006 | 12:41 AM
rebal's Avatar
get your self some F1 mach 1.6s your truck will love them there well worth the extra $ for them next down would be rv275 can be had cheep .But I am real glad I have the mach 1.6s they will run away from 275s
Old 05-26-2006 | 02:16 PM
TORQUE's Avatar
Definately the Mach 1.6's if you tow lots, I do and am still impressed with them.
Old 05-26-2006 | 02:26 PM
Gotlift01's Avatar
Another thumbs up for the Mach 1.6's..........Mach injectors in general are freakin sweet.....but for stock I'd definetely go with the 1.6's......you'll love them!
~Nick
Old 05-26-2006 | 02:38 PM
GlennRMK's Avatar
Yep, 1.6s
Or a cheaper route would be Jammer II nozzles.
And yes a Scotty and 4" would be needed!
Old 05-26-2006 | 03:46 PM
JD730's Avatar
Everyone else steered me towards 1.6's. Glad I went with them, stock pump with a SMARTY and I didn't even have to worry about egt's when I tow (GCVW around 23,000lbs). Stock clutch even took it for alittle while.
Put a HRVP on it and toasted the clutch on the first ride.
Old 05-26-2006 | 05:18 PM
JDGnut's Avatar
I wouldn't go with anything less than 100Hp.. You've got the Comp... you can control EGT's by the settings on the box...
You got a clutch???? Going to need it.. haha..
Old 05-26-2006 | 05:30 PM
Mark Craig's Avatar
JD farmboy,
The new not remanned Bosch 300 HP 275RV's or the Edge nozzle's up to Stage III will be fine! The Bosch are a real inexpensive bolt in, most folks looking for a nice upgrade go this way!
Mark @ DPPI
Old 05-27-2006 | 12:17 AM
JD farmboy's Avatar
Thanks guys, sounds like the Mach 1.6's are what I'm looking for, they would be a nice add on .
Now for a clutch......................
Totallyrad
07-19-2011 08:41 AM
mstep3
12-27-2009 05:43 PM
MikeThomas
04-21-2007 11:25 PM
Micaiahfied
07-21-2005 07:27 PM
Micaiahfied
07-20-2005 11:56 PM
