What Injectors?
What Injectors?
Im about ready to get some injectors, Im looking for some around 100 horses. What would be best for my truck? I will probably stop after injectors. Im on a college budget too. Should I try goin with nozzels or not?
I had good luck with jammer tips on my '01 truck. I installed them myself but did have them pop tested before installation. I really liked the Jammers for performance and price.
Jason
Jason
Call Lenny or Ross at DDP. www.dynomitediesel.com
I assume your budget is tight so tips are going to be your cheapest route but if you want good full injectors jammers are good and inexpensive.
Pm on the way...
Pm on the way...
The DDP sticks are probably the best performance you can get at a little lower cost.
jh
Ok guys, thaks for the help. As far as the $ goes there really isnt a set amount, just tryin to spend as little as possible so I can still pay for my truck, apartment, tuition, food and bills.
I had a set of Scheid lightning injectors at one time. I think they are under $600.Rated at around 100hp. I've always found DDP injectors to be very smokey for the amount of power increase. But my setup is different. I prefer F1 injectors for a couple reasons. They run smoother in my truck than the Scheid or the DDP injectors. Don can make injectors for a specific goal and get them right the first try. But the most important thing to me is that a used set of Mach injectors is always worth more an any other brand. I've had 11 sets of injectors so far. I have traded in Jammer1's and 2's as cores because I couldn't get more for them than the core charge for a new set.
Good luck tweeder_51 with whatever injector you choose.
I love my DDP's, and Lenny is one of the coolest guys to deal with.
The smoke is VERY low for level of injector I am running, and the power gained is more than what the advertised power was. I picked up roughly 180hp at the rear wheels with DDP 150hp injectors on a stock HO pump.
I am now running a custom made size from Lenny that are in the 250HP+ range and I can drive smoke free with the smarty on 9 if i want to. I havent tried without the smarty, but im sure the smoke would never be a problem unless I purposely lugged the engine.
If you want proof here it is
drag racing
http://www.youtube.com/watch?v=JQwSP6OdK54
pulling
http://www.youtube.com/watch?v=suiu7...e=user&search=
drag racing
pulling
