"What HP do you want?" (From another thread)
Old 01-28-2007 | 09:14 PM
J_T's Avatar
J_T
I was asked on a previous post what Hp I expect to get from my truck! Well...HP numbers don't mean anything to me. I'm new to diesels but I know that Diesel HP numbers are different than Gasoline HP numbers.
What are some comparisons with HP...example:
(Feel free to add what you have and can do with it)
[important information to me]
### is what you can expect with Injectors, timing, exhaust, fuel plate
### is what you can expect with the above + average Turbo upgrade
[Fill in and add your own]
>250 will toast (Blank),
>### will toast Gasoline fuel injected V8 2wd trucks
>### will toast most Ford Power Strokes
>### will toast Ford Lighting
>### Will toast stock Mustang
(They are all Fords but I'm thinking of particular owners I would love to beat)
>### will toast Riceburners,
(Feel free to add your own)
Please be as realistic as possible b/c I will be basing my thoughts off of this and I know how some can stretch it like"My truck can....(fill in the blank)" (Toast a C6 vett, beat a crotch rocket, skip across a lake its so fast!)
After knowing those numbers I have one last question. I need to know what HP range can you shoot for and not loose efficiency (mainly mpg) a priority for me!
My priorities are ...
Fix steering and KDP first!
Gauges
then HP hopup, but I am always planning. It would be easier if I knew what is feasible
After I know what I am shooting for I will get a clutch with room to spare!
I look forward to ya'lls reply!
JT
Old 01-28-2007 | 09:42 PM
SSweeney's Avatar
You dont ask for much do ya. I think just some minor upgrades to get you to 700hp should do the trick.
Old 01-28-2007 | 10:08 PM
J_T's Avatar
J_T
Point taken.
I guess I didn't make myself clear...I wasn't trying to accomplish those things...I just wanted to know what HP it took...That way I have a comparison of "real world" (if you can call it that) to real numbers.
I if I say I want 300hp....I don't know that may be large or may be small! and it may not do what I want it to.
I got friends with trucks...I don't know their numbers but I know what they can accomplish so if you tell me numbers compared to what they accomplish I can answer the question ....What HP do I want to get. My list was examples...I would like to know what ya'll can do with your HP numbers?
Thanks for replying and I hope this clears it up a little?
JT
Old 01-29-2007 | 12:08 AM
BigBlue's Avatar
I'm looking for 650+. Mods will be TST COMP, Smarty, water/meth, mach 8's, 62/s400 twins, cam, ported head, nitrous. That oughta get me there.
Old 01-29-2007 | 12:38 AM
Big Smoky's Avatar
LOL! While you're at it, we can throw it all on my truck before we put it on yours to make sure it works!!
Old 01-29-2007 | 12:41 AM
BigBlue's Avatar
If that's the case you can keep the stuff. I most definately don't want your disease.
Old 01-29-2007 | 01:28 AM
Ph4tty's Avatar
With the mods I had when I dyno'd I could sit side by side with a new hemi truck in a 40-110 mph roll on. That won't happen again =P With my current mods I can break all four rears loose on dry pavement from a roll.
Old 01-29-2007 | 02:26 AM
cumminsdriver635's Avatar
You can see my mods, and what I last ran at the drag strip. I feel like I can run high 14's now. My truck isnt what some would consider fast, but it will beat most things I come up against on the street. I figure im making 330hp/750tq or something close to that.
Eric
Old 01-29-2007 | 03:48 AM
TheBigNasty's Avatar
Call me a liar cause I didn't believe it but my current setup kept me a half car length in front of an LS1 SS Camaro until my clutch let loose in 4th. It really does come down to both drivers abilities too. Just wish I could get a clutch so I could dyno and run it at the track to have proof.
Jim Lane
02-02-2011 11:49 AM
PEAKSTRYDE
10-11-2007 05:20 PM
Ridiculous
11-19-2006 11:43 PM
royta
13
02-24-2005 08:46 PM
