What is to be gained by p-pumping a 24v
Old 10-15-2008, 01:24 PM
97 D-Tec's Avatar
ok but ive never seen a truck with a completley stock pump with absolutely nothing done to it melt down an engine
Old 10-15-2008, 03:05 PM
2whistlers's Avatar
Doesn't mean it hasn't happened.
Old 10-15-2008, 06:12 PM
logskidder's Avatar
Its not something that happens very often, unless a mechanical failure is involved. Im not talking about a "stock pump" Im talking about a pump with 0 dollars $$$$ spent
Old 10-15-2008, 06:59 PM
97 D-Tec's Avatar
ok well do u mean one with like a ground down plate? or the stock plate slid ff?
Old 10-15-2008, 07:05 PM
Ph4tty's Avatar
I've got a crazy dream of swapping in a hot VE pump with variable timing and reliability =X
Old 10-15-2008, 07:56 PM
BigErksG2's Avatar
not even just the fuel plate... you can do a gsk with washers and timing by a friend with a kit, may cost you a few beverages.
Old 10-15-2008, 08:05 PM
logskidder's Avatar
Grind the plate, tweak the Afc and mill out the assembly cap.....should be good for 21mm of travel.
Old 10-15-2008, 10:12 PM
The Guru
Mike Holmen's Avatar
Pump conversation work best on stick trucks. The later vp trucks use too much electronics to get the P pump to work. Yes, you can do it but its some tweaking. Its all in the tuning and the parts that you select to set the truck up to run right. A year 98 to 99 stick truck convert easy, later trucks with auto aren't so easy.
R.O.D.P.99
17
10-15-2008 10:39 PM
blackcloud
08-18-2008 08:43 AM
smokin24v
06-18-2008 07:19 AM
1qckdodge
13
08-28-2006 11:35 PM
Tommy93w350
24
08-24-2005 08:02 AM
Quick Reply: What is to be gained by p-pumping a 24v
