What Fuel PSI Guage Ya Using?
I have an autometer z series 0-15 psi fuel gauge mounted in a steering column pod. It is a mechanical guage, and I have a fuel line running straight from in between the lift pump and VP. My guage has broke again. This will now make my 3rd guage I've replaced in a year. They work fine for about 2-3 months then they just start bouncing around and get extremely noisy. I upgraded my lift pump to a holley black before the guage died, and I could easily peg out this guage. So I am looking for a mechanical 0-30psi (maybe?) guage out there that won't break in 3 months. Autometer makes one and it's like $300!!! Anyone got any suggestions on this? Is diesel just hard on the insides of the pressure guages?
Thanks for any help
Tommy
Thanks for any help
Tommy
I use an autometer industrial 0-35psi gauge ($5-10)... I use a needle valve so I dont have the jump and can turn it off in a hurry if I need to... been running it for well over 40k now
Used to have an isolator, and it worked even worse than it does now. Did nothing but jump around all over the place. I hated it even worse than what I have to deal with now.
Later,
Tommy
Later,
Tommy
This has been talked about a LOT on this site - you need a needle valve or pressure snubber to dampen the pulses from the VP-44:
Needle Valve - http://www.vulcanperformance.com/ser...h-8-NPT/Detail
Snubber (I know there is no pic but this is what you want) - http://www.vulcanperformance.com/ser...Snubber/Detail
I have had zero trouble with my Isspro mechanical guage.
So the valve is needed if I want to be able to shut off the fuel flow to the guage, like in case my line leaks or something correct? The snubber is what I need to actually stop the guage from destroying itself right? Thanks for the help guys!!!
Thanks,
Tommy
Thanks,
Tommy
Generally, guys use either...but the snubber will do a better job. You could use a snubber and a ball valve for quick shut off in case the line leaks.
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
