What to expect from the stoopid pump?
Muted User
Tomorrow I'm cranking up my truck for the first time in 8 months or so. Twins, o-ring head, stoopid pump etc... I was wondering I could expect with the smoke? I haven't put the valet switch on yet because I've been kind of anxious to start this thing... but I'm thinking I might need to because I fear that with out the switch that this stoopid pump is going to turn day into night just idling or something. Either that or a solid coloum of unburnt fuel pouring from the stacks. I was also wondering if with that much fuel how long it takes the truck to even warm up idling? If ever :P
I've seen one truck pull a sled with the stoopid pump in it and holy cow He had a turbo similar to a 40 on there at a truck pull and pulling along at 4500 RPMS you literally couldn't see for about 2 minutes after he ran. The smoke just kept coming! but when he let out of the go pedal the smoke stopped. I've got a feeling that you are going to have some fun tomorrow!!! Congratulations! All that work is going to pay off!
Your pump is only going to use as much fuel as the pedal and load tell it to. As long as you did everything right it won't run away on you. Most diesels won't warm up just idling anyway, yours won't be any different.
Expect some major edited fuel. Once you get the tuning down, you will love it, but it will be hit-or-miss for a while till you get it tuned. You are about to have a blast man!!
Mike L
11-26-2012 11:46 AM
dog rocket
10-29-2007 05:28 AM
motomac3
09-06-2007 01:44 AM
clydesdale6
14
01-22-2003 06:10 PM
