what exactly does the "tapped" wire do?
Old 02-15-2006 | 05:06 PM
Bart Timothy's Avatar
Originally Posted by HOHN
The electrical failures are almost always due to excessive heat caused by the much higher duty cycle of the bypass solenoid within the VP44.
Not necessarily, but I don't have the exact figures to back it up right now. Heat also gets to untapped pumps and many electrical failures aren't heat related.
Old 02-15-2006 | 05:24 PM
STACKED's Avatar
Make It Run Like A Scalded Dog. And Pushes Your Vp44 To Its Limits.
Old 02-15-2006 | 06:10 PM
AAmeeting's Avatar
So Marco or Hohn would you venture to say that the comp recieves the signal sent to the solenoid, then sends another short one right after it? I am conviced the comp is hard on the pumps electronics. And a signal flowing back into a Metal Oxide Semiconducting Field Effect Tansistor could be harmfull in a short amount of time causing pump failure. Eitherway now it has come to my understanding that if the metering valve is held open on an almost 100% duty cycle failure is inevitable ie "5x5". This is good stuff!
Old 02-16-2006 | 03:01 PM
duallydave's Avatar
Talking
now im still confused,after reading marcos and hohns replies it still sounds like the comp receives the signal from the ecm and alters it,so my question is why cant the ecm be programmed to have the altered signal already in it?make that software 10 on the smarty,full catcher with comp like fueling.sounds good to me,when i get a smarty i will be waiting to download that new update.
DieselDiehard
12-28-2005 07:33 PM
bws
04-03-2005 09:56 PM
I SPEED
11-05-2004 07:13 AM
mooseman
20
03-31-2004 05:16 PM
TPilaske
16
11-22-2002 09:15 PM
