what do i set my valves at?
Old 10-11-2006 | 08:30 PM
hyunsinsone's Avatar
my truck just rolled over 100,000 and i am installing some 110hp bd injectors. and while i was installing them i was gonna set the valves. wut should i set them at? thank you
Old 10-11-2006 | 08:52 PM
Charlie8301's Avatar
.010 intake .020 exhaust
http://www.dieseltruckresource.com/f...n&onlynewfaq=1
I PASS GAS's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old 10-11-2006 | 09:27 PM
Clayten's Avatar
DTR's Toad Wrangler
I just set mine today at .008 and .018 seems to idle a bit smoother.
Old 10-11-2006 | 11:04 PM
Teddy Bear's Avatar
Guy that did mine said he had good luck with .08 and .18 so thats what mine are set at.
Old 10-12-2006 | 08:29 AM
White00's Avatar
Is there any performance gain at 8 and 18? Also, how tight is too tight if the recomend specs are 10 and 20? I would make mine tighter if it would gain anything, but would hate to screw up a valve, let alone 24 of them
ADAM
Old 10-12-2006 | 09:11 AM
RowJ's Avatar
Adam,
Don't see room for any big performance gain.... Dodge tech manual allows a wide range on setting 24v valve lash....
Intake - .006 to .015
Exhaust - .015 to .030
Book says "Engine operation within these ranges has no adverse effect on performance, emissions, fuel economy or engine noise level."
Most use .010 & .020 with no problems.
RJ
Old 10-12-2006 | 12:51 PM
White00's Avatar
RJ,
Thanks for the info, it doesn't sound like it is worth doing the job again until it's needed.
Old 10-12-2006 | 01:10 PM
satburn's Avatar
I usually set mine above my pistons, but to each their own...
West Coast
12-14-2007 04:49 PM
robert78.5
05-23-2007 08:45 AM
Rampage1967
11-30-2006 07:59 AM
gunracer1
15
08-16-2006 04:56 PM
Irp
05-12-2006 06:22 PM
Quick Reply: what do i set my valves at?
