What can we pillage from a 6.7L?
Old 01-03-2009, 07:25 PM
  #31
HOHN's Avatar
The piston bowl of a 6.7L is much shallower than an older 5.9 piston. At least on the engines I've seen in our build area.
jh
Old 01-03-2009, 09:36 PM
  #32
The Guru
Mike Holmen's Avatar
From what I read, the injector nozzles are designed differently than the 5.9L
Have they done this to promote combustion or to control emissions?
Old 01-04-2009, 07:48 AM
  #33
97 D-Tec's Avatar
All iknow is who ever figures this out is going to be able to make a lot of money because people are going to want stroker kits which means P-pumped 6.7s are going to be doing serious damage
Old 01-05-2009, 11:39 AM
  #34
XLR8R's Avatar
jh
I thought the 6.7L pistons had the same shape (but better alloy) than the '03-'04 pistons?
Old 01-05-2009, 03:58 PM
  #35
The Guru
Hohn, you should snap off a few pics of a 6.7L being assembled in the factory for us to drool on. I'm intersted in the small differences just as information to put into my memory bank. Its suppose to based on the same block, just the bores are slightly larger (closer together) than the 5.9L
I stuck working on the old stuff, the new stuff is still to pricey for me. The high HP deal would be a twin CP pump 6.7L engine. More tuneable than the p pump, but saying that you could still p pump it.
Someone will have a tuner out so we can just turn off the DPF and egr stuff. They have it on the hemi stuff, its just a matter of time. They have kits for off-road use available, EPA been fighting everyone on this one.
Old 01-05-2009, 05:28 PM
  #36
Number47's Avatar
so have we established that the 24valve vp heads will not bolt to the 6.7l block??
BIGOKIE
19
07-27-2013 08:45 AM
Totallyrad
07-19-2011 07:41 AM
t-15 firefighter
01-16-2006 09:08 PM
OH Sick
12-10-2002 04:32 PM
Quick Reply: What can we pillage from a 6.7L?
