What can we learn from these turbo maps?
Hohn, and others, here are some schwitzer/ borg warner turbo maps. What sense can we make from them?
http://www.centralturbos.com/pop-werks6a.htm
Same as you'd learn from any other compressor map.
I personally can't make much sense of them because they are illegibly small.
I can't figure out what the "compressor spec" means. It appears to be exducer and some other spec, but those are VERY low numbers to be trim! I wonder what else they would be?
Wow, a GT 6041 ought to make a great bottom turbo for my 2000HP Diesel Drag Truck! At 180lbs/ min that aught to be plenty to feed a Phat Bastard top turbo.
It's not THAT big to where it would feed a PB. You'd need a turbo in the 240#+ range to feed that big of a turbo up top.
I'm guessing this would be an inducer size around 140mm---huge!
jh
jh
HOHN
42
04-08-2011 01:35 PM
turboman1
12-16-2007 09:12 PM
