What is the boost turnbuckle trick?
I saw in someones post that they were doing some voodoo to add boost? Turnbuckle trick, come on let me in!!! How do I get more?
Not my truck, it belongs to Gotlift01...
It will get you more boost, but without a box, the ECM will see the boost, and defuel, so you won't make any more power.
Originally Posted by Roadrunner
...Turnbuckle trick, come on let me in!!! How do I get more?
Also need a boost fooler (EZ, VA Box, Smarty, etc) before your computer will allow higher boost without defueling!
RJ
HEY THAT PICTURE LOOKS FAMILIAR!!!!!
Yeah the turnbuckle works awesome, I actually removed the spring in the picture off of mine and used the turnbuckle by itself so it's now completely locked shut Need to update my picture now
32-34psi is what I'm seeing now compared to the 20psi I was seeing before the turnbuckle!!
If you have an auto and a boost fooler, take a tape measure and measure from the back of the arm on the wastegate to something up front to attach the other end to. I actually used 2 turnbuckles and hooked them end to end so I had more options to attach the hook to ( plus it made it easier to crank the poop out of it so it didn't come loose and vibrate off ) Not that I ever had that happen
It's actually pretty easy and will cost you no more than $10 bucks MAX to do!
~Nick
~Nick
Locked shut with that much psi? I have that same spring and I got that. hmmm must have cranked the turnbuckle down more than I thought. I used a U-bolt off of the alt bracket and attached the turnbuckle to that.
I had about the same psi with the spring on there as well but just decided to take the spring off cuz I didn't like the way it looked. But that spring I had was one strong little mother, it took some force to even budge that little puppy!
~Nick
~Nick
j
10-12-2003 11:25 PM
