what adjustments need to be made with a #0 plate??
i was wondering what adjusments i would need to make with a #0 plate? is there any governer adjusments needed. The truck is not my daily driver it is strickly going to be pulling/race use. any info would be great
thanks,
matt
thanks,
matt
in some cases you will have to adjust the governor arm!
To avoid that i just cut a 100 plate, it has a hook on the bottom, which prevents the governor to ride under the plate.
does the governer arm adjust easy? thats the screw in the back of the pump behind the plate with the 10mm lock nut right? so all i want to do is make it so the governer arm touches the plate when im done.
what pump is it? if its not a 215 pump you can do a shorter rack plug to get more travel on the govenor arm. you have to mod your afc housing a little too to get the full benifit. dont waste your time if your already have a 215 pump.
afc mod picshttp://www.webshots.com/search?media...ce=search_menu
gov arm adjust: on the back of the pump is a cover plate, that has 2 screws in there, tied together with a cable when not messed with.
in there are two screws, its the bottom one. yep it has a 10mm lock nut,
yeah basicly you want the gov arm to touch the plate, the gov are comes up as rpms rise, so anywhere on the bottom is fine
When I adjusted my arm on my dually, the lock nut and adjusting screw had galled together. Needed a small flat head screwdriver that would fit through a 3/8" socket so I could hold the screw while loosening the nut. Wasn't fun.
Dufrain
14
08-09-2004 06:43 AM
