were to start
were to start
i just bought a 97 3/4 4x4 auto ram standard cab long bed with 155k on it i gave $2000 for the truck ive put a intake and exhaust on it i'd like to over time have about 500hp at the wheels woundering what i should do next i'm putting gauges in it soon truck with be my daily driver with some towing woundering about injectors sizes delivery valves turbo size if i need one yet or could keep stock turbo for now
Keep the stock turbo for now. Wont need to upgrade that till you have quite a bit of fueling.
I would start looking into pump work. Atleast back out the fuel pin.
An adjustable boost elbow is only 20 bucks or so and that will get you a little more air flow.
Then maybe injectors or trans upgrades followed by turbo.
Its an endless slippery slope! Welcome on the ride.
i did have a 94 with work done to it but i didnt do the work i can do pretty much everything but never got into the pumps kinda scared to tear into the pump
my sig has everything done to my truck. the dyno was when it had 40hp bosch injectors in it. i now have marine 370's in it so its a little above that. these injectors seem to be pretty smokey. from my reasearch it looks like DDP's are rated very good on this site. havent seen to many complaints about those.
i, personally, would leave the Delivery Valves to someone else but the rest isnt too bad to do. once you start adding power your tranny isnt going to like you for very long so make sure you look into that.
smoking
08-03-2009 11:27 PM
9512valve
05-07-2009 11:28 PM
mviverit
04-25-2009 10:55 AM
Tuf-4x4
31
08-14-2007 03:20 PM
