went from 215's to DDP4's!
Old 12-23-2006 | 08:23 PM
Forrest Nearing's Avatar
when I swapped the twins for an sps62, I messed up the threads on one of my DDP4's, so I installed some 215's w/ thick washers... tons of idle haze, smokey, truck made 48psi, EGT's rarely saw 1200*. this was with the fuel rack resting on the stock front plug.
retorqued the studs up to 120lbs and installed the 4's today... anticipating a smoke show, I put ~1/8" pre-load on the AFC shaft and took the star wheel from full forward to contacting the spring. it'll bellow a black cloud if you romp it, but it's actually easier to control than it was before!
in 6th it's making 55psi w/ 50psi drive pressure, I didn't see the EGT's go over 1400*, and MY GOD does the turbo hit like a freight train now!
wish list: another 1000rpm and a 5sp
Old 12-23-2006 | 10:16 PM
TxDiesel007's Avatar
Thanks for the post Forrest!
makes me wanna go pawn stuff to get the DDP 4's in, Im sure they are a nice kick over 370s as well, What DVs u runnin on them?
Rick
Old 12-23-2006 | 11:01 PM
Lil Dog's Avatar
Thats the setup I was looking at.. I was looking for reviews on the SPS62, I really like that unit and if it reacts like you say, I will have to ask Santa for another Visa...LOL..
Old 12-23-2006 | 11:32 PM
I think Jeff said he picked up like 60hp over the 370's w/ his twin setup... I'm just running the 181 DV's
I just had a little scare! after all that, I pulled in to get fuel and saw oil dripping under the truck! started freaking out, and headed home... figured the worst I did was maybe blow the side cover seal. turns out I pinched the back valve cover gasket
Old 12-24-2006 | 12:19 AM
thekidfan's Avatar
40hp/120tq over 370's....to the ground! Congrats on getting some fuel back to her bud!!
Old 12-24-2006 | 12:24 AM
thanks, it feels so much better! that oil leak had me sweatin' bullets, I'm supposed to drive to Oklahoma and then back down south of Houston after xmas!
Old 12-24-2006 | 01:13 AM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
Is that 40/120 with twins or with sps 62? and what exhaust housing?
Old 12-24-2006 | 01:25 AM
that was with HX40/HT3B twins
Old 12-24-2006 | 01:40 AM
wildmanben's Avatar
got any idea what teh ddp4s would give me over the 435s?
Old 12-24-2006 | 01:48 AM
Muddin_dude06's Avatar
DDP4's are rated as a 140HP Injector, as well as 435's. They would probably just run/drive a tad better and have a iddy-bitty less smoke... But thats just speculation... lol
Old 12-24-2006 | 02:10 AM
yeah, proably not enough diff to warrant a change...
I've got a good client up in Magnolia!
Old 12-24-2006 | 04:33 PM
thekidfan's Avatar
Actually PDR 40 and PDR 3.5B more air then the standard 3B
Old 12-24-2006 | 05:05 PM
Hemi Dart's Avatar
Question
Forest,
Did you get a deal on your DDP4's? I want a set but can't afford $899.
Old 12-24-2006 | 05:10 PM
they were in the truck when I got it, but I've heard them selling for around $700, not sure where though.
Originally Posted by Hemi Dart
Forest,
Old 12-24-2006 | 06:29 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
What did you do with the lenny's stage 4 injectors?
DD
