In the weeds ? how do you do it?
Try this. The link was wrong.......(Had extra "http://" in it)
http://www.performancecenter.com/pro...tions/Quad+Cab
Cool, thanks !!!!
now a hanger kit for the rear and I will be on the way to pimptom.
You could do a hanger kit but I have found no one that make one yet.
You could pop out some springs, install air bags and that would get you about 3 inches. You could do a flip kit (axel on top of the spring pack) but that would be like 6 inches. and you would need to notch the frame.
I am looking for 2/4 two in the front 4 in the rear, and then some 17inch wheels. The coils for the front look cool. But might need to build my own junk for the back?
Quick reference part number - QR6027
the front coil part number is - 4776
and the rear shackle/hanger kit is part number - 6592
they also have a 2" leveling kit part number for the shackle is - 6590
these are for 3500 Ram DIESEL listed on the beltech website..... i was at the summit racing store in altanta a week ago and they looked up all the prices for me..... if the person you talk to can't help you out tell them you want to talk to someone who has a clue and knows how to use the search function.....
3rd gen wheels should fit because you have 16s and 3rd gens have 17s it might be a clearance issue on the front wheel wells after u lower it, thats just what i think
Just seen this in the classifieds.
Check it out.
https://www.dieseltruckresource.com/...t=7690&cat=all
Check it out.
For the rear just remove the factory blocks, they are either 4 or 6 inches tall, you may need to get a 2" block depending on how low you want to go. This would be the easiest way to go.
the 2wd's dont have that big of a block do they?? my 01 2wd 3/4ton didnt have a block at all and it was factory stock ..... the guy above is right they make a 3/4 drop kit ... its about 400 bucks i think and the 17's fit fine i have them on my 4wd good luck and post pics .. lowered dually's are awesome
Chris
Chris
2wd don't have blocks. i believe it's a little more than 400..... i believe when i priced the front coils and the rear hanger/shakle kit it was in the neighborhood of 600-800 depending on the place that you order them.... i know summit can get the 2" shackle for $100....
here are some links for people who won't search for these parts.....
CLICK HERE FOR THE HANGER KIT AND SHACKLE KIT
CLICK HERE FOR THE FRONT COIL SPRINGS
those are the best prices i've found on those parts.... i've never dealt with that company so i'm not supporting them in any way shape form or fashon.......
yes Yes YES, Thank you everyone. Going to order my junk now !!!!!!!!
How much of a differeance is there in the nitro shocks from there regular ones to there street performance ones? I'm just a freeway flyer pullin a wagon full of hay burners.
Totallyrad
11-29-2010 02:34 AM
