water meth Question
Old 06-01-2008 | 01:59 AM
kgspeed700's Avatar
water meth Question
I was just wondering if its possible to run a water/meth kit on a stock headgasket if you are only goin to run straight water, because tht shouldnt increase the cyl. pressure as much and will it be reliable? a buddy of mine is wondering
Old 06-01-2008 | 02:46 AM
rockjeep73's Avatar
yes it will be fine.
Old 06-01-2008 | 10:09 AM
dzlfarmboy's Avatar
Running just water shouldn't be a problem.
Brett
Old 06-01-2008 | 12:22 PM
Aosipower's Avatar
Yep, you should be good. Straight water is much easier on the engine. You should hear the difference in my engine from when I go from a heavier mix to a more water-downed (so to speak) mix. I personally would not run meth until you have studs and rings or are ready to replace a headgasket.
Good luck,
Alex
Old 06-01-2008 | 01:53 PM
Bjans's Avatar
run distilled water when you do so you dont get mineral buildup in your intake manifold and head
Old 06-01-2008 | 11:59 PM
kgspeed700's Avatar
what bout boost numbers will they matter or make a difference at all?
Old 06-02-2008 | 12:31 PM
RowJ's Avatar
Need to have a boost fooler and some added fueling wouldn't hurt.... to build more boost!
With straight H2O, and a single S300 turbo (at 475 hp), I could not run just H2O below 20 psi. This was with two 625 ml nozzles from Snow's.
Tried it lower and it quenched the combustion fire.
Straight H2O should reduce cyl. head pressure, IMO.
RJ
Old 06-02-2008 | 01:53 PM
kgspeed700's Avatar
Ya so with my setup i was thinkin bout getting water meth as well and running straight water it should be fine?
Old 06-02-2008 | 02:06 PM
RowJ's Avatar
Yup!
Start injecting at 20 psi, with the pump 'ramping up' to full flow at 30-35 psi. Should lower EGTs nicely. Also it will slow the rate of climb before temps get into the red.
I recommend the Snow's Stage Two for daily driving and playing hard........ the Stage Three for towing. Definately get the 625 nozzles (come with it, or use to) and can start with installing just one if you want to be cautious.
Depending on one or two nozzles, Size pump and size of nozzles you get, may be able to start injecting H2O at lower PSI??
RJ
Old 06-02-2008 | 09:47 PM
kgspeed700's Avatar
ya i was lookin at the Cooling mist water/meth kit where you have a remote that injects based on egts not boost what you guys think would be a better choice egt controller or boost?
Old 06-02-2008 | 09:59 PM
kgspeed700's Avatar
or do all you guys stand bye Snows water/meth kits?
Old 06-03-2008 | 08:26 AM
RowJ's Avatar
I prefer the Snow's, because I know it to be great quality.
I know one CoolMist user. His system appears to works as well as my Snows and he's happy with it as well.
If your a Technophile, you'll love the CoolMist. Too complicated for me, but I'm short on patience. It is an excellent system for towing because it uses much less fluid.
I think Snow's Stage three is similar,just was not out yet when I bgt. I'm not sure which has more bells & whistles! Also not sure about CoolMist's injector sizes?
An EGT based system would not be my first choice for drag racing or local street high performance. Comes on to late to do most good. At WOT, all H2O/Meth systems can not keep up with the fuel on a 500 hp+ CTD. They will slow the EGT rate of climb but will not level it off at a significantly lower temp. At least mine won't....still pegs my gauge (1500*) at the strip, but not till the last few hundred feet in a 1/4 mile.
My Snow's Stage 2 will produce 200-250* lower EGT's when towing.... but uses a lot of fluid on long trips. IF you can set the CoolMist.... or the Snow's Stage 3... both ways (EGT's or Boost), and alternate it easily - Best of both worlds!
RJ
jdpiii
06-19-2008 08:34 AM
Mike T.
08-25-2007 10:02 PM
Micaiahfied
03-10-2007 11:04 PM
BigBlue
02-07-2007 11:50 AM
omaharam
04-07-2006 08:48 PM
