Water meth kit?
Old 06-28-2008 | 01:20 PM
kgspeed700's Avatar
Water meth kit?
im gonna be gettin a water meth kit within in the next week and i was wondering what kits you guys like i was looking into cooling mist stage 2 kit with the egt and boost 2d map controller, the painless striker kit, snow performance stage 2 boost cooler kit what would u guys reccomend to get?
Old 06-28-2008 | 01:26 PM
madhat's Avatar
Administrator/Jarhead
I'm not too terribly impressed with mine... I have not see much of a difference.
Why are you getting it?
Old 06-28-2008 | 01:31 PM
kgspeed700's Avatar
egt's r high im planning on running it watered down just to cool
Old 06-28-2008 | 01:43 PM
Rpainter's Avatar
try devilsown kits great product.
Old 06-28-2008 | 01:44 PM
madhat's Avatar
That's the same thing that I was thinkin... that's why I got mine. I see maybe 150-200*, not enough. I still peg a 1500 guage... Save it for a better turbo... that's what I'm doin now, I'd already have the turbo if I would not have dropped the change on the water meth kit...
I'm just one person, tho... make sure that you get more opinion's than mine...
Old 06-28-2008 | 01:53 PM
kgspeed700's Avatar
with the devilsown kit did you guys all tap ur washer fluid tank?
Old 06-28-2008 | 02:23 PM
Rpainter's Avatar
I did at first and then got a used air tank from work for free and mounted it in the bed. also the kit is progressive and adjustable in the cab on the fly
Old 06-28-2008 | 02:36 PM
John_P's Avatar
kgspeed700:
I am currently running one of "Scheid Diesel's 850psi Water Injection Systems" with five (5) nozzles and am very, very happy with it. I previously ran a "Snow Water Injection System" and that worked well until I got above 800 H.P. and the smaller RV water pump they supply could not keep the pressure up as I added more nozzles. I know that DTR "Rpainter" and I are two of the Members here that really work our water systems.
If you get the system, be sure to add some water pump lubricant/anti-rust compound additive in the water as I got a pretty good rust build-up in the intake plenum in my cylinder head by NOT running the additive. One brand you can get pretty easily is "Number 13", made by NAPA. It comes in a small
blue pint bottle and I add one pint to a gallon of distilled water. Also, I would not use tap water in your system. Too many minerals in that water.
Good luck Sir!
John_P
Old 06-28-2008 | 03:17 PM
madhat's Avatar
Good Stuff, John...
Old 06-28-2008 | 04:44 PM
John_P's Avatar
Originally Posted by madhat
Good Stuff, John...
Thanks Mark!
I forgot to tell you guys that my Scheid Water System came with a two and a half (2 1/2) gallon water tank with the electric pump built in. I have that pump and tank in the front part of my pick-up bed inside a plastic
"Rubbermaid" Toolbox that I bought for $22.00 at "Wal-Mart." FWIW, I use ALOT of water with my set-up too. On a average 1/4 mile run on a hot day, I will go through approximately a half-gallon of water on that run!
When I had my "Snow System" on my truck, I used a one gallon plastic G.M. Windshield Washer Bottle mounted on the firewall on the drivers side.
John_P
jdpiii
06-19-2008 08:34 AM
973604x4
44
03-09-2007 02:29 AM
n0ne
10-04-2006 01:50 PM
blackdiesel
13
08-07-2006 09:45 AM
Syndicate
02-28-2006 11:40 AM
