water/meth anyone??
Originally Posted by fjbiker86
I would defiantly run an O-ringed/studed head with W/M....Ive seen two of my friends destroy there head gaskets with w/m after a short period of use....but if you like liven on the ragged edge you might be able to use w/m on the stock head gasket a few times be4 destroying it
Matt- The water/meth will not overwhelm the wastegate as long as the housing has been drilled/ground so it wastegates the front 3 cylinders. My truck makes 40 psi on #2, and 40 psi on water/meth.
Originally Posted by Bushy
PDR sells both the basic and also the more versitile 'stage 2' water meth.
It has controllers so you can set the initial or primary jet to flow and also the secondary (full power) jet.
I made my own system. It wasn't too bad. I did one nozzle at 3.9 gph. I notice a difference when I turn it on. I dont run a wastegate and I run 41psi at WOT. Where can I buy straight methanol? Right now I run washer fluid...
MasseyMan:
Most any race shop can get methanol for you. I see where you are in Illinois. You can also give Brad Ingram a call at Scheid Diesel (Effingham, Illinois) @
1-800-669-1934. He is heavy into the truck/tractor sled pulling and can probably give you the name/number of some vendors who carry it.
John_P
John_P
jdpiii
06-19-2008 07:34 AM
